You can likely get the key code from Triumph via your vin. I *think* the only way to get the dealer to make another key is to have the key code. So, you can contact Triumph or possibly get the dealer to do it. I could be wrong, however.
Of course you recorded your key code into your users manual...of course you know where that was packed? The VIN number doesn't mean $41T if Triumph doesn't cross reference replacement ignition key codes with VIN numbers. What are the chances of that? I just had the ignition switch changed. I'm planning on not loosing my keys.
