Ugarte
Turbocharged
After measuring the the valve clearances I found the number 3 exhaust valves slightly too tight i.e. .12 and .14, they should be at least .15 mm. In order to replace the shims with the correct thickness the cam ladder and cams have to be removed. The manual says the cam ladder bolts are torqued to 10 nm, which is not much torque. The first two were very tight and but I managed to loosen them. The next one was so tight it sheered off the end of the torx bit. So I bought a new torx bit and tried a different bolt and the same thing happened. WTF? And yes I am turning it counterclockwise. Yes, they are cheap torx bits but they should be able to handle 10 nm.
This does not make any sense. Any suggestions?
