freebmwforyou
Standard Bore
- Joined
- May 13, 2013
- Messages
- 4
I have a 2013 R3R, which I removed both baffles from. I was asked to post how I did it.
Here is how I went about removing the 2 baffles and it was rather easy.
1) Using a 2-1/4" bi-metal hole saw bit, you drill out the rear baffle. It will pull right out when you get through.
2)Using a 2" bi-metal hole saw bit, you will drill out the internal or second baffle. This one take a little more time, but isn't too bad.
3) Once you are through the second baffle, it will be held back by a welded flange. Using a chisel and hammer break through the flange and fold over the individual bends. Once you create enough space you can pull out the second baffle.
Now you are just left with the catalytic converter, which I haven't figured out how to remove yet.
I am open to any suggestions. I am about ready to start drilling into it with a long bit.
Sincerely, Brandon
Sincerely, Brandon
