Lucifer Orange
Rocket Man
Hi everyone,
Just after a bit of advice really, I am part way through fitting a set of after market crash bars (prior to fitting of a belly pan) and need to remove the front engine mounting bolt in order to locate the right hand side upper bracket. The fitting instructions are limited and written in German however I have figured out that the bolt does need removing.
I have looked in the manual and this is pretty thin on the ground on specific detail. Assumption is the mother of all **** ups so my intention is to secure and chock the bike, take the weight of the engine with a scissor jack, undo the nut and gently tap out the bolt. Fit the bracket and then replace the bolt, replace the nut and torque up to 80Nm and Robert is your father's brother.
Can anyone see any potential problems doing it this way? I really don't want to end up with bike and engine laying all over the place in loads of bits because I have missed something, be it obvious or not.
Cheers
John
Cheers
John
