Willtill
Nitrous
So....
I was washing my Rocket (engine warm) and after washing it; I towel dried her good. Decided to fire her up and get the water in the nooks and crannies evaporated (couldn't ride her since I was already half inebriated....)
It was starting to get dark out (dusk)
Let her run at idle for about 10 minutes, then twisted the throttle to about 2800 rpm and held her there. I was rewarded with cherry red hot headers; all the way down to the cat bypass.....
Very pretty but also disconcerting...
Have had other bikes with glowing head pipes; but I was very surprised that the Rocket GLOWED RED all of the way down to the cat bypass.
Am running a Standard Rocket 3 tune, secondaries opened 100 percent but nothing else special or messed with regarding A/F or other table modifications via Tuneboy.
So.....
....my question is this. Can someone with a standard tune (unmodified with tune boy) run up your Rocket at about 2800 rpm and observe the headers behind the heat shield? Tell me what you see. Does the entire header "glow red" behind the heat shields? Best to do this in low light conditions.
The reason why I'm asking this, is because I pulled the Standard Rocket Classic 3 tune off of Tuneboys website. If there a fatal issue with the tune (regarding an implied lean condition), I would like to know and the observations of a fellow Captain with an originally installed Triumph tune will help me make that determination.
Or....
....is all of my paranoia a result of cheap British steel?
So.....
Or....
