Boss man
.040 Over
Just checking on this cause the manual is vague. I have the rear wheel off, the seal and snap ring removed.. I first tried to use a blind bearing pulled to pull the bearing from tithe hub and gave up.
I presume I can press them straight thru the hub? What centers the spacer sleev as it looks like it has a smaller outside diameter than the bearing.
