I have adjusted the rear shocks and still no luck with finding the sweet spot. Going to install some progressive shocks and see how that works along with new springs in the front forks from progressive.
I weigh a bit less. Doing the measurements is best if you can lift the rear end. If not, start with 1, assuming there are 5 stops. I have progressive 444 set at the first (top) ring.
