hoopla
Mained to ride!
getting ready to lube the rear spines, need to remove the left shock, but it is really bound, moderate tapping shifts it very slightly. I unloaded the spring a bit, but it didn't help.. Top is loose.
I have an oversized shock, by 1/2 inch.
Thinking that when I loosen the 4 nuts on the bevel box, the shock will actually push the bevel box back and unload itself. Does this sound like a good approach?
I tried lifting slightly on the left side, but it didn't unload the shock.
Suggestions?
Got it off, was stuck to rubber stuff, unloaded then tapped it off, will lube so is not a problem in the future
thanks
Hoopla
Suggestions?
thanks
Hoopla
