Remove bearclaw, remove seat, unbolt the three bolts holding the cluster, lift the cluster carefully to the left, reach in under and unplug the plug underneath, lift cluster off the bike and put somewhere safe, unbolt the two bolts in the front of the tank holding it down, lift the tank, grab the prop from the clamps where it is to the right, on the frame above the engine, wedge the tank up, you're done.
If the rubber gasket under the cluster comes loose, that's no big deal, it's just a bit fiddly to put back on before you replace the cluster, but hardly the end of the world if you're careful.
(Though I'm glad I can ditch mine now that I bought the tank bib from Mustang!)
