Mouth
- Joined
- Sep 28, 2016
- Messages
- 26
- Ride
- 2015 rocket iii roadster
2015 RIII roadster - went for a ride a couple days ago and when I pulled in for fuel noticed a load of white spray up both sides of the engine which seemed to originate from the rad. On closer inspection there were 2 wet spots in the centre portion of the radiator, no fast flowing leak happening but it was wet. Put some leak stopper in there and drove it back home, now I've removed the covers etc and used a heat gun to dry off both areas they just get wet straight away again. I cannot see any visual hole or damage so it must be pretty **** small!
if I drain the rad and use some repair resin around the area will that hold? It's certainly not spurting out under any pressure but it's enough to get blown out onto the engine while I ride.
Thinking of using this stuff - Plastic Padding Leak Fix Sealer Repair Filler Adhesive Water Petrol Resistant | eBay
Any advice is welcome!
