Hopefully, here's a few pics of the Corbin Fleetliner on my R3T.
High quality fiberglass fairing. Paint color match was good but it began to slightly peel around the trim beneath the windshield in just a few weeks. Not very noticeable but should not have happened at all.
I ordered it with the 10 inch shield and wish it was about 3 inches taller. I'm 5' 11" and at highway speeds there is a little head buffeting. It is not adjustable so there is no easy way to stand the shield up a little straighter which I think would help. I have a taller replacement Harley shield but haven't got around to installing it.
The fairing extends out over the grips and makes a tremendous difference in winter riding. Deflects most of the direct wind from the hands. With a good pair of gloves, I've ridden for almost an hour in sub-freezing temps without a problem. Might have to look into heated grips if you want to extend this time.
It mounts using the existing shield mounts, so removal and cleanup is no more difficult than with your OEM shield. The inside of the shell does seem to collect a lot of road dirt.
It will work with the Triumph Driving Lights and and engine guard which was an important consideration for me. There is also room to mount a windshield bag without blocking access to the key switch.
Hope this helps,
db
