Willtill
Nitrous
It's been previously recommended to me; to download and use a Standard tune, as opposed to the Classic tune, due to the Standard tune preconfigured to allow for more power than the Classic tune. For the last thousand miles or so, I have been using the 20222 tune (Standard exhaust, with catalyst)
I have a feeling that she's running lean; I looked in the headpipe while I had the cat box removed, and it's pretty clean and pale in there.
So I'm getting ready to use the 20227 tune (Production pipe, without catalyst).
Does anyone know if the 20227 Production pipe, without catalyst tune is actually for "cat box" removed (with cat bypass installed), or just for an empty cat box?
I was looking at the AF tables, and from reading elsewhere on TuneBoy.au, dropping all the values (overall across the chart) by approximately 1 percent ie; 14.5 to 13.5 will prevent it from running borderline lean. Is that a good place to start?
The only other adjustment that I have done to 20227 is to open the secondaries to 100 percent, all of the time, in all gears.
After asking all of this, would there be possibly a better tune already created to use with my '08 Rocket Classic, with stock pipes, stock air and cat bypass?
Help?
Help?
