Martin-Brighton-uk
Anyone using TuneECU Android version?
I'm trying to find Secondary TPS voltage. Can't seem to find where it is on the Android version.
Quote from the PC version instructions
"With the Secondary TPS in the closed position we can check the voltage. Now here’s an important difference from the information I gave earlier. The secondary TPS voltage is not displayed on the dashboard on the “Tests” page the way the Primary TPS voltage was (as illustrated earlier).
To see Secondary TPS voltage we look in the “Sensors” column on the left of the “Diagnostics” page. Under the label “Throttle” values for throttle position % and voltage will be displayed with the 2nd line showing readings for the second throttle".
But where would that be on the Android version?
Also probably more important. If I am using a map with secondaries at 100% all the time, would it actually matter what the secondary TPS shows anyway!?
Martin
Martin
