Captain Bob
Guys,
I have a question for you... I understand that eliminating the 02 sensor prevents the bike from going in to closed loop and therefore does not allow the ECU to "adapt" or make changes to the fuel map.
Interestingly enough, Although I have the 02 sensor eliminated, I still seem to be seeing the fuel map change depending on how I ride the bike. If I do a long "drone" on the highway, it leans out. If I ride hard and am grabbing handfulls of throttle under a load, it richens itself. I can hear the difference in the fuel map based upon the exhaust note. When runnning rich it is loud and throaty, when lean it sounds like a sewing machine. I do not get any popping on deceleration in either condition (rich or lean)
My R3T has the 02 sensor eliminator installed and I plugged the pipe with an M18 bolt. I have also deselected the 02 sensor using Tune Edit. I have an underseat K&N and am running TORS. I have downloaded, and am running, tune # 20258 with secondaries set at 100%
The bike itself runs great, the changing in the exhaust note is a bit annoying.
Perhaps my understanding of what happens when the 02 sensor being eliminated is either incorrect or incomplete?
Would love to hear your thoughts on the matter.
