Progressive fork spring install general question
Kojack1970
Turbocharged
South Grafton, MA, 01560
2016 Rocket Roadster and 2000 HD Fatboy
For the fork spring replacement going to progressives, is is necessary to fully remove the forks from yokes or can the spring swap be done with the fork tubes still in the yokes? I know many other bikes can be done with the tubes still in the yokes, but it looks to me like that approach on the Rocket is a no bueno. Am I correct?
Tripps
Retired superhero
Florida and NY
R3T,Sprintona,K1200GT, Blackbird,r/65 hack
Touring I did in the yoke, but no idea if applicable to a Roadster.
sonny
Henryetta Oklahoma
rocket three x
I pulled mine. Cleaned everything up and flushed out the tubes prior to installing progressive springs. Replaced fluid with this stuff IMG_0461.JPG Good time to check neck bearings anyhow.
Claviger
Aspiring Student
Olympia Washington
'14 R3R, '02 Daytona 955i
For Roadster, you'll want to pull them, USD forks. While it could be done on the bike, it'll be a lot easier off the bike so you can use gravity to assist while setting fluid levels etc.
Idaho Red Rocket 3
Nampa, Idaho
2006 R3 Standard Bagger w/Fairing
I do mine off the bike. You need to turn them over and pump out the fluid and working on them is just easier off the bike.
