Tony Casey
Finally sorted out my power commander v and AT too work together, the problem i was having there was a bad connection on the positive side. I had connected the power wire to my rear brake light, tapping into the wire with the tags supplied by dynajet this gave me insufficient power to power up the autotune. My question to all of you out there with the same setup where did you draw your power source from, there my be a better solution that i could try.
