headster
- Joined
- Feb 23, 2007
- Messages
- 48
Throttle Bodies
So I pulled both bike's throttle bodies off since I am cleaning both bikes.
05 Standard Rocket 3 part number stamped on each = 1245000-SEP
Inside measurement top = 55.88mm
Inside measurement bottom = 55.88mm
08 Touring Rocket 3 part number stamped on each = 145100-VH6
Then I looked at the injectors and where they seat and everything is exactly the same.
The only visible difference besides the part numbers is the color of the secondary plates and the rod that they connect to, on the 08 they seem to be a lighter bronze color and the seals where the rod goes through the throttle bodies are of a different rubber compound.
As for the cams being different, I will know in a week or so when I pull the 08 apart for its 10k service.
I have successfully run the 05 ecu on the 08 bike when I was bolting the SC on the 05 with no ill affects.
Later
Later
