Rayvin
.060 Over
- Joined
- Jun 29, 2010
- Messages
- 166
Ok, I read all the PC8 threads I could find, plus the directions on Jim's Eastern Beaver site, but I still have a couple of questions and figured I'd ask you guys for advice before I wire the thing up this morning. I did the H4 relay kit last year and like the brighter lights--no brainer on that mod.
Going to put the PC8 rear of the battery, velcroed to the plastic below the seat latch mount. Where's the best place to connect the blue switching wire from that area? Got the 18" relay kit if that helps.
Also not sure which circuits to put which accessories. Here's what I have, previously going to the battery terminals:
1. GPS
2. 12v access. socket
3. H4 relay wires
4. Cruise control
5. 2 strands of led accent lights (PO had them on, never use them but will probably leave them attached)
6. battery tender
I figured I'd leave the batt tender going straight to the battery unless there's a benefit to running through the PC8. Same for the H4 relay wires.
The PC8 gives me two 15a, two 10a, a 7.5a, two 5a, and a 2a fuse. Two unswitched connections and 6 switched.
Any advice would be greatly appreciated, and not sure of the amperage ratings for the various accessories.
1. GPS
3. H4 relay wires
4. Cruise control
6. battery tender
