Looking for a good tune
06 standard stock kn filter with jardines including header .
Right now it seems to be lean
Lots of decel pop
Not so go around town.
Looking for a good tune that allows a guy to ride around town, not just full throttle.
Any advice appreciated
I have a 2005 r3 and I just chopped ten inches off all three stock pipes, and removed all the baffling material, also I removed the cat box and installed the bypass pipe, soon I will do the air box delete and install the map for my pc3; which will be the closest one I can see is the one with D&D slip on which eliminates the cat box and it also includes the air box delete, I suggest trying different maps that are close to your set up and I'm sure you will be satisfied with one. you know that when you do find something close, you can make changes and tweak certain rpm and throttle position settings which will add or remove fuel where you believe deceleration pop is occurring, you simply need to spend time feeling out what you like and become satisfied with, I myself love fiddling with all the different options and potential that pc3 gives us; I hope that at least, if this does not solves your issue, that it will inspire you. If you do however discover a killer map, in the future, please share it so we can have more leverage over our beast "lol" BE SAFE!
