All good advice above . The Pcv comes with generic maps that will be in the ball park , but not perfect . The Dyno tuner , should write you a custom map depending on your and the bikes requirements . Any decent tuner can also access your bikes ecu , depending on year of bike , can remove any speed restrictions , open up the secondaries to 100 % , lower the fan temperature and raise the red line . Eliminate the majority of Decel pop , remember ? straight through pipes are always going to pop to a certain degree . To eliminate it completely , is to effectively detune the bike and you don't want that ! Once this is done , the custom map is stored in the PCV. New maps can be written and also stored if you do any further mods . The benefit of the Dyno tune is that you know that the bike is running to it's optimum , taking all riding conditions into account! I have no experience with the auto tune , but the guys here that use them swear by them . Personally , I like to have that dyno read out , which shows exactly what your engine is doing . That said , the cost of that peace of mind , does tend to work out more expensive than the auto tune . Accessing the bikes ECU and tweaking , plus custom map on the PCV cost me a tad under £400 GBP, as opposed to around £300 for the auto tune and £20 for the lead and tune ecu .
Bear in mind , I still use the tune ecu for servicing !
