Hammer
Hey Guys,
'05 classic. I have a p1108 code that wont clear, just keeps coming back. Ambient air pressure sensor circuit high voltage. Service manual says to unplug the sensor and check for short between ecu pin A01 & A23.
So first off, im confused as to which sensor is the ambient air pressure sensor. The manual lists the following;
Air Pressure Sensor
MAP Sensor
Inlet Air Temperature Sensor
And then descirbes the following;
Intake air temperature sensor - situated at
the front of the intake duct, above the camshaft
cover. As the density of the air changes with
temperature (therefore the amount of oxygen
available to ignite the fuel), an intake air
temperature sensor is fitted. Changes in air
temperature are compensated for by adjusting
the amount of fuel injected to a level consistent
with clean combustion and low emissions.
Barometric pressure sensor - situated
beneath the motorcycle seat, in the top of the
airbox. The barometric pressure sensor
measures atmospheric air pressure. With this
information, the amount of fuel per injection is
adjusted to suit the prevailing conditions.
Manifold Absolute Pressure <MAP) sensor
- situated at the front of the intake duct, above
the camshaft cover, connected to each of the
three throttle bodies by equal length tubes. The
MAP sensor provides information to the ECM
which is used at shallow throttle angles (very
small throttle openings) to provide accurate
engine load indications to the ECM. This
degree of engine load accuracy allows the ECM
to make very small adjustments to fuel and
ignition which would otherwise not be possible
from throttle angle data alone.
Based on that I've assumed that Air pressure sensor = Intake air pressure sensor = Ambient air pressure sensor. Correct me if I'm wrong.
I then unplugged it and did the continuity test between ecu pin A01 and A23. No continuity which leads to a wire issue. I happen to have a spare wiring harness, so I grabbed it and it as well does not have continuity between those pins. Having a hard time believing both harnesses have the same wire issue.
Also is the Air pressure sensor/Intake air pressure sensor/Ambient air pressure sensor supposed to be hooked up to a vacuum line? I currently have it hooked up to a line that goes to the 4 way T fitting, connected to the 3 lines that go to each throttle body. I'm assuming this is proper but I've had this bike apart so many times its hard to remember.
I do have a rammair fitted.
Thanks in advance guys.
Air Pressure Sensor
MAP Sensor
