BlackSails
Where'd all the tread go?
So several weeks ago out of the blue, my bike wouldn't start. Just clack & wouldn't turn over. After checking wires switches etc. I gave up & took it to the local Nashville Triumph dealer. Two weeks later they said, it's starting now, but not running right and will only start IF the power commander is disconnected, but wont run right cause the O2 sensor isnt connected. I informed them that the O2 sensor is a broadband from AT and the the O2 is turned off and the ecu connection is plugged ... so that's not it. I suggested reloading the tune & they said "Don't take offense to this but U seem to know more about how ur bike is set up maybe u could pick it up and reload the tune, we have 2 hours in it but will wave the charges. See what u can figure out and let us know if u do. So ... I did, towed it homethe next day, connected Tuneecu & right out of the box I could see things werent the right. Rev limit changed, speed limit changed, O2 was turned on. Etc. So I reloaded Nels Touring Map & started it. Seemed to run a lot better BUT no vacuum and throwing P1105 now. I checked map sensor wires and rubber caps (I have the canister removed and all 7 throttle body vacuum nipples capped) one of the caps U missed & was badly cracked, so I replaced it, crossed my fingers, but still getting the code and no vacuum readings
Is my next step to order a new map sensor? Did I miss something? I'd hoped to ride to BBBQ this week but Its looking like it ain't gonna happen
Any suggestions!?? Thanks!
