Oil tank line grease?
leatal
Turbocharged
Dothan, Alabama
2014 Roadster
Changing the three oil rings in the bottom of the oil tank. Upon removal, I noticed the 2" metal tube with the two oil rings attached was covered with clear grease (looks like electrical grease). Anyone know what type of grease should be applied upon reinstall?
warp9.9
Pocałuj mnie w dupę
Forest City Illinois
07 Rocket
if your talking about the oil tank feed to pump which is in front and the one in the rear which is oil return anyway what your probably see is petroleum grease. Its so the O rings slide in without getting cut or damaged. You can even use engine oil if you want or any grease as it does not take much.
leatal
Turbocharged
Dothan, Alabama
2014 Roadster
Only the rear extension pipe with the two O-rings had grease. Quite a bit of grease between the O-rings. Seemed at lease two tablespoons as the entire gap between the pipe and the case was full of grease. Perhaps put there to prevent corrosion and keep water from seeping into case hole above the lower O-ring?
EasTexRIII
Uneasy Rider
Tyler, Tx
05 Rocket III, Trek Road bike, Trek Mountain bike
Or cosmoline part in packaging that didn't get wiped off before assembly
joesoap
Its because the section of pipe is unpainted or plated...packed grease protects;)
warp9.9
Pocałuj mnie w dupę
07 Rocket
I'd say your probably right then
AdBlock Detected
I've Disabled AdBlock
