Dave S
Standard Bore
ROCKET 3 2005
Hi folks can any one tell me what is the Procedure is for getting the oil circulated and up to pressure after a rebuilt. I almost back on the road again.
My guess would be the only way to prime the oil first would be to take the clutch basket out and then spin the pump. Hopefully you used assembly lube to take care of the bearings prior to assembly. Oil pressure will come up pretty quick upon start up. With assembly lube I never had a problem with mine.
