evomind
.060 Over
Tucson, Az
Hey folks...
Is there any way to remove the oil filter without loosening the front cooler? (2020 R3)
I doubt it but thought I would ask.
Moving forward, would a K and N filter allow filter change without loosening anything else?
Thanks
I doubt it but thankfully it's just a few bolts & it swings out of the way.
Can't see any reason another brand filter would make any difference unless it was substantially shorter.
Hey folks... Is there any way to remove the oil filter without loosening the front cooler? (2020 R3) I doubt it but thought I would ask. Moving forward, would a K and N filter allow filter change without loosening anything else? Thanks
You can drive a Phillips screwdriver in to it to get it loose then see if it comes off.
All the clips are flimsy!
Ill do it the right way the first time, then see if I can trim the bottom opening and use a K and N for the future.
Everything is pretty accessible on this bike.
What's the K and N part number if anyone has it handy.
