This is probably obvious to most, but on my 600 mile oil change I did not change oil filter. Manual said remove 2 front screws, tilt cowl forward to get to filter. I took out screws, removed plastic around the screen or air filter. Then removed the screen that snaps in place. It was not obvious at this point how to remove filter so buttoned back up. Where did I go wrong besides starting this!
Also manual did not say whether to check dip stick sitting on bike or on the stand. I sat on it and now wonder if this is correct and maybe overfilled. If I did, I could remove oil filter once I know what went wrong and get some oil out.
Btw that oil looked really clean, guess cause new besides few miles.
My aggrevation started at the beginning when the oil pan I used with the cap on the side for convenient pouring leaked! Cap just would not seal so I was wiping up oil as I went.
Also not easy when final drive drain it was hard to have the pan close enough to plug cause tire was in the way. Whinning I know.
Thanks in advance!
Thanks in advance!
