As long as the HEAT RATING and size are CORRECT there should be no issue - The question is - Are they?
Nology Silver™: Identify your Spark Plug Part#: Types: (hot 4......8 cold) Heat-range
150 141 010 H4YS M14x1.25 – 0.46" reach,
Tapered, 16mm Hex (5/8")
Non-Resistor
6-8 150 141 020 G4YS M14x1.25 - 17.5mm reach (0.7"),
Tapered, 16mm Hex (5/8")Non-Resistor 6-8 150 141 030 D4YS M14x1.25 – 19mm reach (3/4"),
Gasket, 16mm Hex (5/8”)
Non-Resistor
6-8 150 141 040 L7YS M14x1.25 - 19mm reach (3/4"),
Gasket, 21mm Hex (13/16")
Non-Resistor
4-6 150 141 050 L4YS M14x1.25 - 19mm reach (3/4"),
Non-Resistor
6-8 150 141 060 L0S M14x1.25 - 19mm reach (3/4"),
Non-Resistor
9-10 150 141 070 R4YS M14x1.25 - 25 mm reach,
Non-Resistor
6-8 150 141 080 ER4YS M14x1.25 – 26.5mm reach,
Gasket, 16mm Hex (5/8")
Resistor
6-8 150 121 090 B2S M12x1.25 - 19mm reach (3/4"),
Gasket, 17.5mm Hex
Non-Resistor
8-9 150 101 100 A0S M10x1 - 19mm reach (3/4"),
Non-Resistor
9-10
In 12mm and 10mm thread there are no real options. And they have NO resistor.
NGK spec is
DPR8EA-9 - Heat grade 8 and resistor.
If it were me - I'd NOT do it.
Where's Mr Tripp?
