tdragger
Just finished installing the Rivco Ignition Switch Relocation Kit and buttoned up the Roc and gave her a wash. Saddled up for a shakedown cruise and discovered that I had no horn, turn signals or brake lights. Checked the fuses and all are fine. Headlights, both high and low beam, work just fine. The Roc starts and growls as usual.
Will the much more wise than I out there guide me to where to start looking? I can't imagine that water got into the turn signal switch housing but that is a possibility. Or do you think that I may have unplugged something behind the steering head? Last place that I can think of would be behind the lower left panel where the ignition switch was moved to. I had to push around a lot of wires in there. Help please!!
