Dawg68
Nitrous
Good day all;
A couple of days ago I ordered a set of auxiliary lights for my R3R. Here are the specs;
F4 Hyper
Features
• 100% optically clear PMMA LEXAN lens • Instant on/off, no warm-up
• Operating Temp: -40 ~ + 145 deg. • Oversize heat sink
• Low power consumption, Over/Under Voltage protection
• IP69K Waterproof Rating and E-Mark• Military GORE standard Breather
• Unique Durable Mar/UV resistant painting technology on cast aluminum housing
• Sealed waterproof Quick Disconnect Deutsch connectors
• Military standard GJB 150 & US MIL810-STD,
High Temperature,Low Temperature,Temperature Shock,UV,Humidity,Salt Fog,Sand and Dust,Vibration,Altitude
• CE & RoHS Compliant & E-Mark certification
Specifications
* 10 degree SPOT pattern OR 40 degree FLOOD pattern
* 40W per pod
* 1.5A draw
* 3300 Lumen per pod ( 6600 per pair )
* Beam Distance: 585M for FLOOD
* Beam Distance: 780M for SPOT
I paid $250 for the set which includes the wiring harness.
I should have them early next week and as soon as I get them installed I'll shoot out a couple of pics. These are pretty powerful lights for the price. Like most I was not very happy with the stock headlamps so the first thing I did was change the H4 bulbs to the PIIA bright whites and they make a huge difference over stock bulbs. I can't afford day makers at the moment so this was the logical first step. I figure if these lamps work as well as the specs say then there may be no need to upgrade the headlamps any further.
I'll post my findings as soon as I get them installed.
Cheers
F4 Hyper
Features
Specifications
* 40W per pod
* 1.5A draw
Cheers
