Fork rings that are 58mm diameter to mount after market turn signals and lose the giant silver buy magnets.
Sturdy tubular luggage rack to replace the pillion seat that uses the same bolt points as passenger seat, offer chrome and black.
Side mount license plate bracket with integrated white led plate light, offer chrome and black. A lot of the existing brackets don't work well with the rocket because of the bevel box.
Bolt on brackets that require no drilling for an Ohlins steering damper!!!!!!!!
"Blank" oil tank badges with just a flat surface when bolted on, so they can be custom engraved by the owner, offer black and chrome.
Dual 5 3/4 to Single 7" headlight conversion kit...
Relocation kit to move the ABS pump out of the spot where the turbo is supposed to be. Silly Triumph, they got ABS pumps and turbos confused apparently. Kit should move the pump to where the stock air filter lives.
A radiator that is a bit taller but a bit more narrow that all aluminum and at leat equals the stock rad performance. This includes designing the replacement shrouds.
Bolt on servo driven cruise control kit. The cruise control products exist, but an installer kit so it's a bolt on affair instead of custom work would be nice.
Ignition relocation kits for 09 and newer R3s. Should include the bracket so people don't have to mangle the bracket already down there.
Foot board kit for roadster that isn't crazy over priced.
Some sort of light weight foot peg, shifter, brake pedal replacement kit that is light weight. I swear taking 100lbs off this bike would have been incredibly easy had triumph even made the slight attempt at doing so.
Adjustable length kick stand with a larger (wider) pad to distribute the load over a larger area. I literally caught my bike twice as it was about to fall from the kick stand sinking into the ground
No idea how to do this one but: monoshock retrofit kit to lose the dual old school shock design. There areally more advanced monoshock's on the market than duals from what I've seen, plus it saves a ton of weight.
Small LED bar, tiny, with 4 LEDS blue green amber red.
Red= ECT over 120c
Amber=ECT between 90 and 120 c
Green =ECT between 75 and 90 c
Blue=ECT under 75c
LED strip brake light with integrated turn signals that is molded the same shape as the rear fender. Include a metal blanking panel to replace the stock tail light. Offer with panel inn flat black, gloss black, or primer.
That's l that comes to mind off the top of my head....lol.
