mm-dmoney
Standard Bore
- Joined
- May 31, 2022
- Messages
- 7
- Ride
- 2011 R3R
Hi all,
I've recently had an issue where my GPS will no longer detect Neutral. I removed it from the housing and am able to rotate the sensor to various gear positions, but it just jumps from 1st gear to 2nd gear without sensing Neutral. Some other forum posts talk about removing the pin (and spring behind it) and cleaning, however, the pin on the sensor feels pretty solid in the sensor and not sure if it is a different version of GPS. Can it be cleaned or otherwise repaired?
