BigDog1954
Standard Bore
- Joined
- Jun 2, 2014
- Messages
- 5
- Ride
- 2014 Rocket III Touring
Hi everyone, I just bought a 2014 Touring with ABS brakes and I am looking to move my foot controls forward 3". In order to do that it will require extending the brake line from the rear master cylinder back to the abs unit. I have already done some preliminary exploratory work and It appears the only way to access the brake line connector block is to remove the air box ( the connector block appears to be just underneath) in order to access the brake line connector block. It appears in order to remove the air box will require raising and/or removing the fuel tank to disconnect the air duct from the air box. If anyone else has done this or has any other ideas on how to access the brake line connector without removing the airbox I would really appreciate any suggestions.
Thanks in advance,
Thanks in advance,
