Need a bit of help wiring a screaming banshee air horn please?
Discussion in 'BearClaw Corner' started by Allan S, Dec 31, 2017.
  1. Allan S
    Allan SSimple African lad with a Rocket
    Country:
    Canada
    427
    Featured Threads:
    9
    Media:
    11
    443
    73
    Toronto Canada
    Ride:
    2016 Roadster-skunk
    IMG_0624.JPG IMG_0610.JPG I installed a screaming Banshee horn in the spot where air cleaner was pre Ramair.
    The instructions are clear and tell you to run the 2 blue wires to the horn location and connect the" two blue wires to the existing horn wires - it doesn't matter which one goes to which" .
    I'm not sure how to proceed because the Rocket horn has a ground wire on the one horn terminal, so 3 wires, one on one terminal and two on the other not the one to each terminal of the horn that I expected to find.
    The Screaming banshee is wired directly to the battery for both power and ground. Can I exclude the ground wire to the horn button and just connect the other two as the whole horn system is grounded at the battery?
    What to do?
  2. Old N' Grumpy
    Old N' GrumpyLiving Legend
    Country:
    United States
    2,029
    Featured Threads:
    9
    3,378
    823
    Ft.Lauderdale, Florida
    Ride:
    2014 Triumph R3R & 2005 Harley FatBoy
    Skip the horn...use middle finger!:rolleyes::whitstling::D
    Steel, stavros and Fingers like this.
  3. phar2slo
    phar2sloTurbocharged
    Country:
    New Zealand
    768
    Featured Threads:
    8
    929
    203
    Christchurch
    Ride:
    2006 classic
    Gee Allan you may want to think twice about hitting the horn button.
    As looks like it will give a bit of a vibration to the left ball in that location.
    :rolleyes::rolleyes:
  4. Allan S
    Country:
    Canada
    427
    Featured Threads:
    9
    Media:
    11
    443
    73
    Toronto Canada
    Ride:
    2016 Roadster-skunk
    I'm praying that the Corbin seat I just got has enough padding to prevent that.
    I didn't remove the curved hose that fed the air box from the filter when I removed the stuff for the Ramair and the mouth of the Horn fits directly into that so I'm hoping the sound will be carried forward a little.
  5. Rocket Scientist
    Rocket ScientistGrand Exulted Poobah
    Country:
    United States
    5,875
    Featured Threads:
    99
    Media:
    5
    8,121
    823
    Spring Lake, Michigan
    Ride:
    Black 05' Rocket III standard
    Just hook the two blue wires from the banshee, one to each of the wires going to the original horn terminals. Don't worry that one terminal has two wires, keep them together like they were a single wire.
  6. Allan S
    Country:
    Canada
    427
    Featured Threads:
    9
    Media:
    11
    443
    73
    Toronto Canada
    Ride:
    2016 Roadster-skunk
    Thanks for the help.
    So hook into either one of the pair on that terminal or put on a new spade terminal with all three (blue and the original 2 on that terminal )?
  7. Rocket Scientist
    Country:
    United States
    5,875
    Featured Threads:
    99
    Media:
    5
    8,121
    823
    Ride:
    Yes sir !
  8. Ishrub
    IshrubRetired and loving it!
    4,687
    Featured Threads:
    59
    4,750
    823
    Ride:
    R3 Roadster,Sprint ST 1050 ABS, BMW R100RS sidecar
    I just got an email my 'Bird' gloves should arrive Weds.
    Bird gloves
    [​IMG]
    Old N' Grumpy likes this.
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
