radar
OK so having had the RAASK rearsets fitted and loving the new riding position but not the shabby quality I bought some rearsets off ebay and modded the RAASK brackets and knocked up a little extra bracketry to roduce this
and a closer look here:
(The rusty lump of metal underneath the engine is part of my garage door lock) The hardest part was drilling the bit of aluminium rod to make the gear change linkage. I drilled and tapped the RAASK bracket and mounted a 5mm thick aluminium plate that the footrests were bolted to. The right hand side rest didn't need a adapter bracket it mounted direct to the RAASK one. I've to work out how to mount the master cylinderbut will post an image when I've done it.
The oil tank embellisher and temperature guage were gold plated using a home kit - the results are pretty good if I do say so myself
