Whippet
- Joined
- Mar 28, 2015
- Messages
- 21
- Ride
- Roadster
Hi guys, just in the process of rebuilding a rocket engine, ordered the correct main bearing shells according to crank journal od and crankcase id, fitted them, torque and degrees main bolts. Problem started.. crank tight to turn, removed everything and double checked journals, crank okay, checked crankcase.. found 3 of the 4 mains the same size and then measured the main bearing that the crank uses as a end float cap to find its slightly smaller than the rest.. what to do ?? I an using red shells.
