That is great news. If we can use TuneECU I could put the saved $$ towards other toys. Did you use a map from the site && make modifications to it? Both fuel and ignition?
In a perfect world there would be a dyno and a trusted tuner in the area I could work with, have not found one yet but still looking.
Slotting somebody else's tune in and tweaking without a way to MONITOR the effects (seat of pants does not count - sorry) is less than recommendable.
Yep, and actually could be dangerous to you your bike and wallet.
A big concern of mine is the bike running too lean.
What I have done so far is...
Make a copy of the original tune.
Really study the manual for TuneECU to learn what can be modified, where to modify it and what effect to expect.
Study the different tunes available for a similarly setup bike and use the compare feature of TuneECU to see what the tuner changed / left alone and try to understand why.
I then installed a wideband O2 sensor and data logger to monitor the AFR, MAP, TP, RPM, etc. Perhaps not a perfect solution but gives valuable information as to what is going on.
Might add exhaust temperature readings for the individual cylinders.
Ride and then study the logs and make tiny changes where necessary, only change one thing at a time and test ride again. Going to take a long time.
IMHO being able to adjust the timing as well as the fuel is far superior to fuel alone.
There have been some surprises the first is when I turned the O2 sensor off with TuneECU the cruise AFR went from mid 14 range to mid 12 range. Fail safe for O2 sensor failure? Would run fine like that but not great for fuel mileage. Without some way to monitor would not know what was going on.
Rick
