Longer brake line Roadster please.
Discussion in 'Rocket III Resources' started by Landstar, Apr 23, 2018.
  1. Landstar
    Landstar Adapt adjust overcome
    Country:
    United States
    239
    Featured Threads:
    12
    214
    53
    Morgantown Wv
    Ride:
    2015 Rocket Roadster
    I am lost fellows, this is the reponse I got From Barnett, so where do I find a 4 inch longer brake line. Will all the Thunder Bird cables fit, I see that they are about 3 inches longer, anyway I want to order this stuff, but I will not be home for a month. Does anyone know the lengths of the Roadster cables, I will just order those from Barnett, and look for the brake cable. It's going into the shop for this, I do not have time to do it, so I need the cables before I take it to the shop.Thanks for any info.
    Here is their reponse.
    We are unable to do the brake line. It has ABS and needs a special block which we do not have.
    There is no problem making the other cables in any length you need. In black casing, special length cables
    would be $163.00, this would be the throttle cables and the clutch cable. I checked the other source
    for Triumph brake lines, Speigler, and they also do not make this line.
    When you determine the length you need and are ready to order, our sales desk will assist you.
  2. R-III-R Turbo
    R-III-R Turbo Warp Speed: ENGAGE
    815
    Featured Threads:
    17
    Media:
    85
    1,128
    203
    Ireland
    Ride:
    '10 Supercharged Carpenter'd Roadster, 04 Hayabusa
    Which brake line do you want to be 4" longer?
    I can measure that line on my Roadster, give you the measurement to add 4" to, and order them online.
    I've got lines custom made before by these guys (click here) a few times, found them and their product excellent
    Wide choice of colours and end fittings
    [​IMG]
    Landstar and TasRocketRider like this.
  3. Landstar
    Country:
    United States
    239
    Featured Threads:
    12
    214
    53
    Morgantown Wv
    Ride:
    What I am finding out is, the ABS is a problem on the 2015 the ABS is all one unit.
  4. Landstar
    Country:
    United States
    239
    Featured Threads:
    12
    214
    53
    Morgantown Wv
    Ride:
    brakelinetech@galferusa.com these guys here were very helpful couple different blocks, where everything hooks up, that has to be changed. They can supply with everything to change it. But it's pretty complicated, so when I get home my mechanic will get with their technical Department, I spoke with Donny who was real helpful and said to have the mechanic call him and he would tell him what measurements he needed and how to reroute everything with the new blocks nd lines that he would be sending. I don't know if ABS is worth all the problem I also called Triumph, they were no help. I told them part of owning a motorcycle it's customizing it. And their design on the ABS made it very complicated. Thanks a lot for trying to help.
  5. Landstar
    Country:
    United States
    239
    Featured Threads:
    12
    214
    53
    Morgantown Wv
    Ride:
    Spiegler and Barnett had no solution.
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
