desoter
Standard Bore
Good day folks got an odd issue going on with my R3T hoping you fine people can help.
I have a 2009 R3T with just under 17k miles on it, I have a K&N air filter and the TOR pipes with the factory tune for these pipes.
About 2 months ago I noticed a very slight sputter at very small amounts of throttle, like less than 5%, low speed cruising say 20-30mph in 3rd gear.
The sputter has gotten worse so that the bike hitches and lurches a lot, it idles fine, and any throttle input above the tiny area its fine.
I took the bike into Triumph of Seattle and they re-flashed the tune and then we let it idle for 20 minutes to reset the fuel map. Bike ran fine for around 40 miles but has started to sputter again.
Another symptom is that when this throttle issue is happening the bike backfires out the exhaust, so for the 40ish miles after the re-tune no backfires, but they have started again.
Any thoughts? I'm leaning towards the TPS just off hand, when the dealership check there were no codes from the bike.
thanks!
thanks!
