voila pour vous si vous avez un traducteur en français
Here it is, if you can translate the French:
Basically,
1. Make sure ignition is OFF.
2. Empty the tank to facilitate lifting
3. Remove the fuse for the fuel pump, under the seat
4. Start the motor and run until it quits, to empty the fuel line
5. Turn OFF the ignition.
6. Remove the strap for the tank
7. Undo the attachment at the rear of the tank
8. Lift the rear of the tank 5 to 10mm
9. Remove the fuel line from the injector fuel rail
10. Return the tank rear to its place and loosely reattach the tank
11. Lift the front of the tank 10 to 15 mm
12. Near the front of the tank, remove the cover for the fuel pump
13. Disconnect the hose for the evaporative control system
14. Lift the tank
NOTE: Do NOT disconnect the coils
