When you put the led headlights in, you mentioned there was no parklight so you taped up the wire...there is the problem. Because the parklight bulb is a push in type, you need to leave the bulb in and then tape it because the contacts inside(Where the bulb pushes in) will touch and short out.....I know, cos I did it too!..it dosnt hurt if you leave the bulb taped up and tucked in the back behind your leds...hope this fixes it.
