garyculb
LED & Signalminder
Have a Kisan Signalminder. It works OK. Decided to add LED lights to the turn signals. Big mistake. Now front turn signals are dim but functional. Back turn signals do not work at all. Contacted Andy in Tech Support at Kisan;
“The turn signal indicator which flashes on the dash to tell you that the turn signals are on is the culprit. Since your bike has only one indicator for both sides, it will be out-of-balance with the LEDs. There's a tiny push-in bulb under the dash indicator, remove it.â€Â
