Torque loss ALERT!
You are going to lose 27 ft lbs of torque when you switch to a free flowing Intake...@Claviger had the dyno numbers for a RAMAIR on the stock bike and it lost the 27 ftlbs...I did the RAMAIR on a stock Classic and it neutered the bike and made it rev alot faster......I do not know anything about tuning btut when you pull that stock airbox-the beast will not produce massive torque at LOW RPMS. Some things are left untouched and I have regrets I pulled my stock air box off as it changed my bike from a R3 to a FJR 1300...Fast revving lower torque...But then again I am running the base map 20215 until I get my Crat delete and TORS on with a 20228 map.
I still wonder if a hi flow intake bike can produce big torque at low rpms.....eg...2300.
@dougl at what RPM are you producing the most torque?
BTW...I am running an AFR+ which there seems to be some controversy whether it over rules the fuel maps in the ECU as it uses its own lambda and the ECUs lambda plug is sealed with a Null Cap Dobeck...
PS....Does anyone know the diff between a 20228 and 20050 map?
Cheers....Greg
