phil ewins
Wales
Triumph rocket3 roadster 2015
I recently remapped my 2015 roadster and noticed that the digital display had changed to kph. Can it be change back to mph using tuneecu or will it have to be mapped again using a mph template tune???
Remove the cylinder head and tap the middle piston top three times as you stand on one foot,,if that fails press the reset button (black button on the left of the speedo) for about 4-5 seconds it will go back to MPH
Make sure it's on the odometer setting when you do this. I recently had a similar issue and kept trying to reset the clock till I realized what I was doing!
I think it may possibly be an issue caused by a battery that is due for replacement, I was struggling to get enough voltage for tuneecu to connect properly when it happened. Then I replaced the battery and it connects every time no problem now but unfortunately the mileage hasnt gone back down.
