Once you are done doing what ever you've done, swipe the screens to the right, shows gauges instead of maps screens,
engine is not running, power is on,
touch the ECU tab, touch tasks and adjustments,press reset ISCV, goes to TPS first, gives voltage, .60v+/- .02v,touch again, then it will proceed to ISCV, .72v +/- .05v, it will prompt you when done, next etc, a touch is needed to finish things up. Once the clicking stops you're done.
when you are at TPS you can adjust the TPS on throttle body 3, loosen set screw then turn TPS slightly, you'll observe the voltage changing. You can see the TPS by looking slightly under the tank. Once set, click next/done
Brings you to ISCV observe voltage, adjustment is on throttle body 1, again you can see it under the tank, 7mm wrench adjuss the nut,
hope this helps you out,
Hoopla
