Jared
I can put the key in, lights come on, etc. but sometimes it won't even crank. It is in Neutral. Just replaced battery, thinking the 3 year old battery I had may have been an issue. Still nothing. I have opened up the starter button and cleaned those terminals, so that should be good. If I do manage to get a little crank, it will only turn over a couple times, then just die like there's no voltage, gauges go out, but will do their startup routine after a few moments, as if there was a significant power interruption/reset.
Another symptom is when I turn the key on, even pushing the horn button does nothing, except when I release the horn button, that's when I get a super faint dying blip out of the horn. Headlights also seem pretty dim. I think maybe the clutch switch could be an issue, as messing with it can sometimes get the starter going, but surely I've got some amperage bottleneck somewhere. So this leaves me with 2 thoughts:
1) Maybe someone more experienced/better versed in electrical schematics can tell me if the starter relay could be the cause of these symptoms?
2) How do you remove the clutch switch? I checked my service manual and while I can search it (digital copy) for the keyword "clutch switch" and get many results, none of them allude to how to remove the thing.
