rng3
"There is no replacement for displacement"
- Joined
- May 8, 2018
- Messages
- 420
- Location
- Chester county, West of Philadelpha
- Ride
- Rocket 3 roadster 2017
The stock Intake Air Temperature sensor (IAT) is mounted in a location to monitor the Air temperature entering the engine. It is one of the several sensors the ECU uses to to determine how much fuel to inject at any given time. When you switch to 3 separate air cleaners such as K&Ns you need to find a suitable location for the sender. Just hanging it from the fuel rail may not give accurate readings. Somewhere on this forum there was a picture of the stock sender mounted to the top of a K&N.
The IAT is simply a NTC thermistor (negative temperature coefficient) resistor Thermistor - Wikipedia
a resistor that the resistance changes with temperature.
Most NTC seem to be rated by their resistance at 25 deg C. There is also the temperature range, curve, resistance tolerance, etc.
NTC can be quite small and inexpensive. Maybe a 1/8” diameter. I have purchase several 2K, 2.1K 2.2K to compare to the stock.
I put them and the stock unit in a plastic bag submersed in a container of heated water and compared the resistance reading at various temperatures. I got pretty close. I then mounted the closest NTC bead on a small tube and drilled a small hole in the bottom of the center air cleaner to put it right in the air flow.
What I was wondering is if anyone knows the correct NTC to use to mimic the stock one. So far one of the 2K seems to be the closest. With some after market fuel injection kit you set the value at freezing and then boiling water and the computer determines the curve. We do not have that luxury here.
Thanks,
Rick
Thanks,
Rick
