RhinoOK
Rocket 3R in my garge
- Joined
- Nov 14, 2021
- Messages
- 138
- Ride
- 2020 Triumph Rocket 3R
I installed a USA style cigarette lighter power port on my 2020 Rocket 3R in the location for the Triumph DIN socket. Was able to remove the left panel and find the blue tape holding the OEM connector for the DIN socket. I cut the connector and soldered in terminal leads for the cig lighter I found on Amazon (2 for $10). There is no room for cig adaptor with the install ring. I was thinking about shaving down the 2 hole bracket but didn't want to modify the bike like that. Simplest solution was to tap in the adaptor under the bracket and it is in there quite solid with no modification to the bracket.
