I believe the Triumph Maintenance Manual states the resistance across the injector coil leads should be 12.5-14 ohms or they need replacing. I just had mine tested/rebuilt and they were 11.8 ohms for one injector and 12.0 ohms for the other two, which still met injector manufacturer's specifications. As mentioned above, check to see if there is a drastic difference between the three and if the number one injector is considerably different than the other two, then either replace it or send it off to get professionally tested, cleaned, and rebuilt. Cheap enough at $18 per injector (I recommend RX Injector Service in Houston, TX). He does not charge for any injector failing the electrical tests, plus he has rebuilt injectors to replace the OEM injectors for a fraction of the cost from Triumph. Personally I would just send them all off to be professionally checked/serviced and rebuilt, especially if you have some miles on them.
