Son_Of_Dog
Unfailing Millennial
I've been working on the bike again today. When I got on it this morning I noticed that the indicators weren't working. When the indicator switch is moved to either side the headlight and cluster will flicker slightly, but the indicators do not light. I thought it might be an issue with the LED bulbs that were in the front, but replaced them with standard bulbs and got nowhere. After a small battery of tests and a large battery of reading old threads, this is what I've figured out:
- I believe that I have some LED bulbs that don't cause a problem, because while they would flash quicker than regular bulbs they wouldn't visually cause any other problems.
- After some continuity testing, I found that in the rear indicators, both the positive and negative side of the bulbs are continuous to the ground on the battery. I'm not certain this is how it should be, but I am certain that I don't understand it if it is.
- I do not appear to have voltage to the wires going to the indicators in the plug in the headlight bucket, whether I have switch on the left hand switch cube activated or not. I also could not find voltage at the switch.
- After studying the wire diagram pretty intensively, I'm not really sure where I should be looking for voltage going further backward (toward the battery)
