Al Burdon
For the Electrically Savy I have a question.
My 2013 R3R has a sidecar fitted and as such the left hand indicators have been removed.
The sidecar has front and rear indicators that are LEDs and are patched to the rear indicator circuit under the right hand side cover.
Sometimees they work as you would expect and sometimes they do not work at all.
I also have the keyless ignition and fuel bot 2 fitted.
I have a self cancelling indicator relay fitted as well.
On start up I now check if the indicators function and if they do not I turn off the bike by using the kill switch and turn back on. This generally resets the indicators.
Sometimes during a trip they may stop functioning and the kill switch cycle may or may not fix the problem.
Yesterday I removed the right hand switch block and when replacing I noticed the behaviour when tightening the screws. I then adjusted the tension until the indictors worked repeatedly.
Today after a couple of hours riding I noticed the indictors were not working again so I cycled the kill switch and function returned.
No other issues are presenting themself.
So any advice on what to check would be appreciated.
Cheers
Al
Cheers
Al
